jonmck's avatar
jonmck
One of three satellites repeatedly showing a TON of times on firmware upgrade page.....WHY?
Within the app, it is no longer showing my three satellites.  It only shows the router. When I login to the web admin panel, and click on attached devices, it DOES show the three satellites there.  HOWEVER, when I click to check for firmware upgrade via the web admin panel…why does it show the “Upstairs Closet” satellite sooooo many times?  See below.  You will see the RBR50 at the top, "Living Room" satellite below that, then the "Upstairs Closet" satellite listed a TON of times and then at the very bottom, you will see my last satellite called "Master Bedroom".  ***I removed half of the "Upstairs Closet" entries in the below table as this forum would not let me post over 20,000 characters.***
Model Name
Device Name
Current Version
Status
Router
RBR50
RBR50
V2.7.3.22
No new firmware version available.
Satellite
RBS50
Living Room
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Waiting for connection
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Upstairs Closet
V2.7.3.22
Satellite
RBS50
Master Bedroom
V2.7.3.22
  • FURRYe38's avatar
    Try a factory reset on the RBS and RBR and setup from scratch.
    Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi (WiFi5 RBK10, 20, 30, 40 and 50 Series). Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    Thank you.
    • jonmck's avatar
      jonmck
      Thanks!  That worked....I did a factory reset and setup from scratch.
