Crasje
Feb 20, 2026Tutor
Orbi 870 Anywhere access error
Hi, I have an error while trying to turn on the Anywhere access. It was on but since 2 days gives me an error (see attachment). " some error occurred while enabling disabling anywhere access"...
- Feb 20, 2026
Internet search turned up this:
Orbi RBR50 - Cannot Enable Anywhere Access in iOS App | NETGEAR Communities
Crasje
Feb 20, 2026Tutor
What version of the Orbi app do you have installed on your phone or pad?
Latest version, 2.51.0.37
What brand and model phone or pad are you using?
Iphone 16 pro, iPad pro (M4)
Does this happen with a different phone or pad?
Both
Remove the app from the phone or pad then reinstall the app?
And rebooted iPhone in between
What Firmware version is on the Orbi system?
Also latest vv10.5.20.4_1.3.5
Private IP address disabled
Yes
Is IPv6 enabled on the RBR?
No, since I am using the router in AP mode. This might be a thing, I just received a new Modem of my provider to enable more than 1GB i-net. But my ISP router is IPv6 enabled.
Using ISP detected DNS or custom DNS?
Same? Since I am using in AP mode. My ISP Modem uses specific DNS's for IPv4 and IPv6.
Does this help?
Feb 20, 2026Guru - Experienced User
Try the Orbi system in router mode, use the ISP routers DMZ for the RBR in router mode to avoid the double NAT condition here. Then see if using Orbi app works, then see if you can connect Orbi app to the Local connection to the system, then see if you can disable Anywhere Access while in the Local connection mode on the app.
How is the RBR configured for AP mode? Using Dynamic IP configuration or Static configuration?
Possible that Orbi app and AP mode and AA may have a problem or the ISP router maybe interferring with something.
