jaireaux2
May 20, 2022Follower
Orbi app dashboard won’t connect from satellite
When I’m connected to a satellite (RBS350) and I pull up the Orbi app on my iPhone, I get “Unable to connect to router RECONNECT”. If I’m connected to the router (RBR750), the app works fine and I can use the dashboard. The satellites are using backhaul Ethernet, if that makes a difference.
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi jaireaux2,
Are you still experiencing this?
Can you access the Satellite Web UI?
Please provide the router and satellite firmware version and Orbi App version.
Blanca
Community Team
