BretD
Mar 30, 2018Administrator
Orbi App, Easily Setup, Control and Monitor your Orbi Whole Home WiFi
Do you have the Orbi App?
The NETGEAR Orbi app makes it easy to set up and personalize your Orbi WiFi System. With the app, you can install your mesh system in few steps - just connect your...
Seattleeric
Apr 11, 2018Initiate
I have exactly the same issue as TTTraylor. I was able to test speed for two days now I get Connection Failed message even though I have connectivity. I’ve tried rebooting the router and it has not helped.
Anonymous
Apr 12, 2018Same here.
- do33grsApr 13, 2018AspirantSpeed test fails here as well. Just set up system today.
- tsgt2007Apr 13, 2018AspirantI have the same problem with my I phone. I can not check the speed of the internet with the app. I receive an error message as well. I think it was the Apple lastest iOS update that screwed it up.
- TTTraylorApr 13, 2018Aspirant
That's a good observation. I am using iPhone X. Could very well be the issue.
- budyApr 13, 2018Luminary
Yeah - seems to be an iOS issue. My Orbi is still on 2.1.2.18 and my iPhone X won't run the speedtest anymore using the Orbi app. That worked before the iOS update, so probably this is not Orbi's fault… well… at least this time. ;)
Well… no… ;) I just ran the speedtest from within the RBR40 and that didn't work as well. Seems to be an issue with Ookla or the way the Orbi tries to connect to their servers, as their speedtest seems to work generally. However, Ookla's servers seem to have undergone some facelifting and maybe that's the cause.
- FURRYe38Apr 13, 2018Guru - Experienced User
budy wrote:Yeah - seems to be an iOS issue. My Orbi is still on 2.1.2.18 and my iPhone X won't run the speedtest anymore using the Orbi app. That worked before the iOS update, so probably this is not Orbi's fault… well… at least this time. ;)
https://community.netgear.com/t5/Orbi/Connection-Failure-on-Speed-Test/m-p/1550252#M28113
Run any speeds tests with a PC and a browser or the Ookla speedtest.net app from a mobile phone until the Orbi app and any onboard router apps are fixed. NG is aware of the issue. This is a service issue with NG.
Yeah, I figured that out just after I hit the reply button. ;)
