Barrydet
Mar 28, 2026Tutor
Orbi app problems
I upgraded to the Orbi 700 series. I followed the app instructions. During the instructions I renamed the factory issued account name to a personal account name for the system. Moving on to add th...
CrimpOn
Mar 28, 2026Guru - Experienced User
Do you have a device with a large enough screen to run the Orbi web interface?
Desktop, laptop, tablet?
I have found the Orbi 'app' to be a bit tricky when connecting to the router. Sometimes, it asks for login information, and it is not clear whether the app wants the web administration credentials or the app login credentials. (It often suggests email addresses that I have not used for YEARS.) Using the web browser interface avoids that ambiguity.
- BarrydetMar 29, 2026Tutor
I learned a solution by contacting 24/7 tech support by phone. The solution is to depress the reset button on the rear of the 870 router for 60 seconds two times. The LED power indicator lamp will turn from green to orange color. This action will erase the memory of the 870 device. The device will return to the factory set SSID. This will allow the Orbi app or the web browser interface to find the device and link to the device. Thanks to everyone for the coaching tips.
- FURRYe38Mar 30, 2026Guru - Experienced User
A 15 second press on the reset button and release should have worked as well.
