rogbar
Sep 11, 2025Follower
Orbi App shows connected devices as offline
Just set up new Orbi 870 router and satellites. Many devices are listed in the app as offline, but they're working fine. I have re-booted the system and it doesn't change. Is it possible that Arm...
Sep 11, 2025Guru - Experienced User
Does the RBRs web page show the devices as being connected?
Does Disabling Armor change anything?
What mobile platform are you using? Apple Or Android?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
