mgcblossom
Mar 29, 2026Guide
ORBI application issue
First ORBI system was active on the ORBI application, was able to view all details. We purchased a second system for a Delaware location; application dropped our first, although picked up our second...
mgcblossom
Apr 06, 2026Guide
Appreciate all the assistance, with the 2nd ORBI system, we did use the application option (set up a new orbi system). Seems the application only recognizing the last system installed.
Apr 06, 2026Guru - Experienced User
You may need to get to the other system and connect your mobile device there. While there disable AA then re-enable it. I have noticed this when having two systems online, that one of them doesn't get fully accessible until you do this odd routine. I Just put a different Orib system online, Orbi app only sees the prior one that was removed so I'll have to get the phone re-connnected to the new system locally, then cycle AA off then back ON. Will get access then.
