Romitelli1
Jan 20, 2020Aspirant
Orbi iOS Remote Management
Orbi Remote Managment isn’t working on my Orbi iOS app. I can connect locally. When I tried to toggle on the enable remote management in the settings on the orbi app I get an error saying something went wrong. I see everyone saying to fix remote management they need to disable and enable but again I can’t toggle it on to begin with. Any suggestions on fixing this?!?!
- Scholver63AspirantOrbi iOS Remote Management isn't working from outside,can't save Remote option in Settingssame issue here; Orbi Remote Managment isn’t working on my Orbi iOS app. I can connect locally. When I tried to toggle on the enable remote management in the settings on the orbi app I get an error saying something went wrong.I see everyone saying to fix remote management they need to disable and enable but again I can’t toggle it on to begin with. Any suggestions on fixing this?!?!
- TindoAspirant
I'm having the same problem. It was working fine unit sometime in November last year. No make what we try it says something went wrong. Version number is 2.5.0.108 (the latest).
Orbi App remote management just doesn't work. It doesn't toggle at all.
Netgear needs to work on making things easier and not frustratingly difficult.
- Christian_RNETGEAR Employee Retired
Hello chirayudave,
Is you Orbi router in access point mode? Have you tried reinstalling the app? May you also provide the following info as it'll help us understand more:
iOS App Version:
Router Model:
Router Firmware Version:
Thanks,
Christian
- gdf1960Aspirant
The app is unreliable and has become a nuisance. NETGEAR should not include endorsements in their products that are of poor quality and lack sufficient customer support.
- FarmerBob1Luminary
I could turn on Remote Management in the ORBI App, but it did nothing in the RBR850. But if I turn it on in the RBR also, then it works great.
