woodshap
Nov 04, 2021Aspirant
Orbi RBK50 router not connecting to my Plusnet Hub One router/modem via ethernet cable
I have tried resetting my ISP router by powering off (as Orbi instructs) and even pressing the reset button, connecting my RBR50 router (having also pressed the reset button no that also) by ethernet cable, then powering the RBR50 on, numerous times, but the RBR50 router just flashes on and off White, after many minutes, rather than going solid White, as it sholud, I believe.
I'm about to return it but thought I'd seek help on any further ideas please. Exasperated!!
The ring light (at the top) of the Orbi router goes through a sequence of colors during startup, which should end with a solid blue light and then no light at all:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
It would be worth trying what is called a Factory Reset:
https://www.youtube.com/watch?v=cMw4ePACgc4
Holding the paperclip in that tiny reset hole for a long time is the key. It may take 10-15 seconds for the Power LED to begin flashing amber.
- woodshapAspirant
Thanks so much for this fast response. The RBR50 has no sequencing of lights on top at all - just the white light on and off. Also, thanks for the tip about holding a paperclip in to the Reset button for more than 15 seconds. Holding it in for at least 30 seconds cause no change on the power light.
I'm thinking that the unit may well be faulty.
If you are able to return it, I would do so.
