DrJohnLogan
Jun 25, 2025Aspirant
Orbi RBKE963 no connection
Today out of nowhere, both my satellites lost connection to my orbi router. I tried for hours to reconnect them, even resetted one of the satellites, then both, and eventuelly I also resetted the...
Jun 25, 2025Guru - Experienced User
What plotform is the Orbi app on? Apple Or Android?
After you factory reset the system, try setting using a wireless or ethernet connected PC or laptop? https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
What firmware version is loaded on the RBR and RBS?
Jun 27, 2025Guru - Experienced User
New Orbi app updated:
https://community.netgear.com/discussions/en-home-orbi-app/new-orbi-app-versions-and-updates/2308199/replies/2460203
