vicko
Jan 15, 2019Aspirant
orbi remote access
Hello, trying to enable remote access.
I open the app for orbi on my phone and go in to enable remote access. I click the slide and it says enabled, and then I watch as the slide goes back to o...
ekhalil
Jan 16, 2019Master
vicko wrote:
....... I click the slide and it says enabled, and then I watch as the slide goes back to off. Any ideas?
By any chance, is your Orbi set in AP mode? Remote management is not supported in AP Mode.
Chuck_M
Jan 16, 2019Mentor
If you are on an android device, I recommend you:
- Go to settings -> App data
- clear the app cache and app data for the Orbi App
- then Uninstall the app
- Reboot the android
- Reinstall the Orbi App
- See if the app works on your wireless network (internally)
- Turn off wireless on your phone
- See if the app works remotely (through your phone data plan)
If you are on android, there should be a similar thing you can do.
