vicko
Jan 15, 2019Aspirant
orbi remote access
Hello, trying to enable remote access.
I open the app for orbi on my phone and go in to enable remote access. I click the slide and it says enabled, and then I watch as the slide goes back to o...
ekhalil
Jan 17, 2019Master
grubbster wrote:
This happened with my Pixel 3 also. It happened about the same time as the January security update. Was working before and quit after the update. That's probably what borked it.
Have you tested with another device?
grubbster
Jan 17, 2019Aspirant
No, I don't have another device. I do know if was working before the update and not after. The Pixel is Google's flagship phone so it gets updates before any others. My guess is something in the update broke the app. More people will probably experience this as it comes out on other devices.
- FURRYe38Jan 17, 2019Guru - Experienced User
I would contact Google and let them know what your experiencing and also let them know it had been working before your device was updated.
- ekhalilJan 17, 2019Master
Device vendors usually do not accept any individual app issues, they will ask you to contact the app vendor.
Yes, or contact the App Mfr. If the OS broke the app, then both app Mfr and Google need to correct it.
The "Remote Management" activation in the app goes through the Netgear cloud so you need to be connected and authenticated towards NG cloud to do any changes.
Do you see your router in the app's home menu as connected (with a green status)? Please see below:
