vicko
Jan 15, 2019Aspirant
orbi remote access
Hello, trying to enable remote access.
I open the app for orbi on my phone and go in to enable remote access. I click the slide and it says enabled, and then I watch as the slide goes back to o...
grubbster
Jan 17, 2019Aspirant
No, I don't have another device. I do know if was working before the update and not after. The Pixel is Google's flagship phone so it gets updates before any others. My guess is something in the update broke the app. More people will probably experience this as it comes out on other devices.
Jan 17, 2019Guru - Experienced User
I would contact Google and let them know what your experiencing and also let them know it had been working before your device was updated.
- ekhalilJan 17, 2019Master
Device vendors usually do not accept any individual app issues, they will ask you to contact the app vendor.
- FURRYe38Jan 17, 2019Guru - Experienced User
Yes, or contact the App Mfr. If the OS broke the app, then both app Mfr and Google need to correct it.
- SabbsolApr 15, 2019Tutor
I have the same problem, enabled on Web interface, won't enable on Orbi app.
How do I access it remotely using the Web interface?
