ScubaSteve63
Mar 28, 2022Aspirant
Orbi Satellite not showing in web interface but showing in IOS app
The Orbi Satellite is not showing in the we interface but does show in the IOS app. I have seen posts for the opposite of this but not vice-versa. Thanks, Steve
- Mar 29, 2022
What version of the app are you using?
Maybe CrimpOn can comment as well.
Might try a full on Factory reset and setup from scratch.
Might try this version of FW as well:
https://community.netgear.com/t5/Orbi/Missing-Connected-Devices/m-p/2143646#M126249
Mar 28, 2022Guru - Experienced User
Is it working?
Can you hardwire into it and it works?
ScubaSteve63
Mar 29, 2022Aspirant
It is hardwired and it's working well...just confused on why the web interface does not show it
- FURRYe38Mar 29, 2022Guru - Experienced User
What Orbi model is this?
What web browser are you using?
- ScubaSteve63Mar 29, 2022Aspirant
RBR50 with chrome as browser
What model is the RBS? 50 as well?
Happens with MS Edge or Firefox?What firmware version is loaded on the RBR and RBS?
