ScubaSteve63
Mar 28, 2022Aspirant
Orbi Satellite not showing in web interface but showing in IOS app
The Orbi Satellite is not showing in the we interface but does show in the IOS app. I have seen posts for the opposite of this but not vice-versa. Thanks, Steve
- Mar 29, 2022
What version of the app are you using?
Maybe CrimpOn can comment as well.
Might try a full on Factory reset and setup from scratch.
Might try this version of FW as well:
https://community.netgear.com/t5/Orbi/Missing-Connected-Devices/m-p/2143646#M126249
ScubaSteve63
Mar 29, 2022Aspirant
Same result in Edge
Firmware is 2.7.3.22
Thanks
Mar 29, 2022Guru - Experienced User
- ScubaSteve63Mar 29, 2022Aspirant
App Version is 2.15.1.2
Everything is working...just odd that the web interface is not showing satellite or attached devices and the IOS app does
- CrimpOnMar 29, 2022Guru - Experienced User
I agree that the most frequent posts are concerning issues with the way the 'app' displays components and the typical advice is "check the web page." This one may remain a mystery.
There would be no harm and almost zero effort in rebooting the router and satellite. (not a "Factory Reset". that can be a lot of effort.)
- FURRYe38Mar 30, 2022Guru - Experienced User
Might try a factory reset on the RBR and setup from scratch.
- ScubaSteve63Mar 30, 2022Aspirant
I am going to try the .33 firmware update tonight and will let you know if that works.
Thanks,
Steve
Updating the Router and Satellite to V2.7.3.23 fixed the problem !
Thanks for all the help !
