cargal
Jan 29, 2026Aspirant
RBE 773 Anywhere access
I have just installed my RBE 773 and inadvertently enabled Anywhere access and can not disable it - i also think it may now be causing me issues that the app dashboard shows local devices as offline ...
CrimpOn
Jan 29, 2026Guru - Experienced User
Anywhere Access is a feature of the Orbi app that can be enabled/disabled from the Settings Menu. Click the "hamburger menu" icon in the upper left of the screen. Select Settings. Then select Anywhere Access.
