jwalls2
Oct 17, 2025Aspirant
connecting Atomi outdoor lights
I have Atomi outdoor can lights that I assume have to run on 3.2 and not on 7 mesh. How do I get them to work with 7 mesh? I don't want to use old Orbi system just to run lights. Thanks for your...
Oct 18, 2025Guru - Experienced User
Are the Atomi lights new or the router new?
What router do you have?
If you upgraded router, you should have been able to just program the old routers ssid/password into the new one and devices should auto-switch to the new one. I've been doing that for years.
