birdsafe's avatar
birdsafe
Devices List
The other day I opened the Orbi app and opened the device list and the display was a bit different, it had devices listed by band (2.4hz, 5hz, 6hz) and I think it also had a toggle for each device (t...
  • ross8888's avatar
    Nov 02, 2025
    Yeah, that view you saw was probably part of a recent Orbi app update or a test feature they were trying out. It sometimes shows up briefly and then goes back to the regular list after an update or restart. There isn’t a setting to switch to the band-sorted view yet, but it’ll likely return once Netgear rolls it out fully. Just make sure your app’s up to date for when it does.
