yolo1010's avatar
yolo1010
Orbi App - device manager and remote access not working - iOS
I can only use the web interface. I have an  orbi 870 and I cant use device manager or do remote access.    The error is "Sorry your device list failed to load. Please try again later."   I've do...
  • KevinLiT's avatar
    Sep 17, 2025
    Hello yolo1010​ ,
    Welcome to the NETGEAR Community!
    I understand that you are experincing issues using the Orbi App with your Orbi 870. Please uninstall your Orbi app then reset your network settings on your mobile device. After successfully reseting the network settings on your mobile device connect to your Orbi network then reinstall the Orbi app. Please keep us updated on the progression of this issue!
    Best,
    Kevin
    Community Team
