mgcblossom
Mar 29, 2026Aspirant
ORBI application issue
First ORBI system was active on the ORBI application, was able to view all details. We purchased a second system for a Delaware location; application dropped our first, although picked up our second...
mgcblossom
Mar 30, 2026Aspirant
Yes, RBE370 for New Jersey, RBE370 for Delaware currently only the Delaware location is visible on the ORBI application. My concern is not being able to check on the New Jersey system while also having the ability to view Delaware.
Thanks
Mar 31, 2026Guru - Experienced User
Something to submit a bug report or contact NG support and ask about if two same model systems are supported on the Orbi app at two different locations. I would think it should be. I've not had two same model systems connected at one time in two different locations.
How to report a bug on the Orbi App FAQ | NETGEAR Communities
I presume you have Anywhere Access enabled on the Orbi app for both systems? Might have to get to the other location and disable AA then re-enable it.
