Willybob
Jun 10, 2022Initiate
Satellites not showing up on Network Map (Orbi RBR350 with 2 satellites)
I have an Orbi Mesh system (router = RBR350, Firmware version = V4.4.0.10_2.10.63) with two compatible satellites. As you can see from the app screenshot below, it knows it's got two satellites and ...
Jacky_or
Aug 21, 2022Tutor
Just brought rbr350 1+2 set
Exactly the same problem
2 Satellites not showing up in iOS app
How the hell can you position the satellites well when you are unable to see the signal strength?
Very disappointed experience.
I answer very satisfied at the end of the setup since I don’t have chance to explore the problem yet.
This is the first time I brought a Netgear product, may be the last time.
Should have brought ASUS ZEN WiFi set
CrimpOn
Aug 21, 2022Guru - Experienced User
Blue is Good. Amber is "not so good."
Have you looked to see what the Orbi web interface says about the satellite connection?
- Jacky_orAug 21, 2022Tutor
Thanks for the info, well that's the first time I saw this information since I open the box.
will try move around and play with the lights.
netgear, simplicity is good, just don't think everyone is a fool and hiding all the information.
BTW what's taking so long to fix the network map? 2 months for fixing this basic feature?
come on....#RBR350 #RBS350
- FURRYe38Aug 24, 2022Guru - Experienced User
Be sure to submit a problem report if you see issues with the Orbi app:
- Jacky_orAug 30, 2022Tutor
CrimpOn
Thanks for the hint.Finally I can't stand with the useless Mobile App.......
Then I try the web interface, everything shows up as expected.Rodox forget the mobile app, try the web interface (default address: 192.168.1.1)
@Netgear
what a stupid useless Mobile App!
unable to change most of the "advanced" setting by mobile app.....
And Netgear you want me to "shake" to report bugs?(https://community.netgear.com/t5/Orbi-App/How-to-report-a-bug-on-the-Orbi-App/m-p/2140980#M3630)
sorry there are too much your app is missing, won't waste my time shaking around to report basic problem for you.
Look around your competitors then you know what you are missing from the mobile app.
your mobile app just not up to standard
