Napkcin
Oct 18, 2026Tutor
Smart Parental Control is also effected
I am having the same issue. Smart Parental Control is also effected. It does not track usage and history. You also cannot pause any devices. It can only connect to the router through " access anywher...
- Oct 19, 2026
Restarted my phone and now it works.
Napkcin
Oct 18, 2026Tutor
Just an update. I am using my wifes IOS 26.6.1 and the orbi app can login and also SPC works.
