WPaulB
Nov 24, 2025Aspirant
Upgrading my current Orbi RBR20 router + 2 satellites to an Orbi 45 + 2 satellites.
I can connect them via my Orbi App but then get the message that they are not connected to the internet. How do I resolve this please? Thank you.
WPaulB
Nov 25, 2025Aspirant
Thank you for your advice. Our new system's Model number (from the box it came in) is RBKE963B-100APS.
The process I initially tried was through the ORBI app on my iPhone that I use for my existing ORBI RBR20 system. I connected the new router to our modem and restarted the modem and the new router. It showed up as being connected but not connected to the internet. I tried this a couple of times with no success.
When I tried to resolve this through my ORBI settings on my app, I got a message telling me my login credentials were incorrect. I then tried to resolve it through the web-based settings and got a bit lost in how I could resolve the issue that way also, so I reconnected up my old system again in the meantime.
Hopefully you can help me now?
Thank you
Nov 26, 2025Guru - Experienced User
WPaulB wrote:Our new system's Model number (from the box it came in) is RBKE963B-100APS.
So a 960 system.
WPaulB wrote:The process I initially tried was through the ORBI app on my iPhone that I use for my existing ORBI RBR20 system. I connected the new router to our modem and restarted the modem and the new router. It showed up as being connected but not connected to the internet. I tried this a couple of times with no success.
I suggest doing a paper-clip reset of the new Orbi, and then setting it up again using the web UI (ignoring the app for now). Netgear does provide free installation support (once you register the product). Contact them using this page:
Googling for support can lead to a scam site, so best not to do that.
