smarttech
Aug 16, 2026Follower
What is the best way to improve WiFi coverage throughout a large home?
I’m looking for advice on improving WiFi coverage throughout a larger home in Melbourne, Aus. The main router provides good speeds nearby, but the signal becomes weaker in bedrooms and other areas fu...
Aug 17, 2026Guru - Experienced User
What is the size in sq feet of this large home?
Building material of the home?
Basement is not recommended for the main router unit. Main level or 2nd level is recommended.
30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
I have a 5000 sq ft home and run two RBS. Works well.
MESH tends to be better than extenders as the satellites integrate with the router unit and offer backhaul support, wireless or ethernet.
smarttech wrote:I’m looking for advice on improving WiFi coverage throughout a larger home in Melbourne, Aus. The main router provides good speeds nearby, but the signal becomes weaker in bedrooms and other areas further away.
Would a mesh WiFi system generally be a better solution than adding WiFi extenders or additional access points?
I’d also be interested in hearing how others have handled WiFi dead zones and maintained reliable coverage across multiple floors.
