rbarkley82uk
Dec 04, 2025Aspirant
Wired Devices not showing on Orbi App
I have two devices (Playstations) that I want to pause at certain times. I can do this when they connect to WIFI, but I purposely purchased an additional satellite so I could hardwire the two Playsta...
Dec 04, 2025Guru - Experienced User
What Orbi system model do you have?
What firmware version is loaded on the system?
What model# additional satellite did you get?
Does the playstaions connect to the RBR and are seen there?
Are the game consoles seen on the RBRs web page at all?
rbarkley82uk
Dec 05, 2025Aspirant
Hi Its the Orbi 773
The firmware is the same on the main and the two satellites - V10.5.20.7
The Playstations connect both wired and wireless but dont show up on the app or web page if wired. However, my Hive Hub is wired to the Main Router and it appears on both the App and the Web Page. so it seems to be anything hardwired to the satellites
