acchen's avatar
acchen
Follower
Jul 06, 2022
2.4ghz wifi fo my satellites disabled again⋯
This method only worked like a day for me, and 2.4ghz wifi fo my satellites disabled again⋯
Is there other way to solve this problem?
  • acchen See previous posts in this thread
    Try changing channels and set "Preambule modus" to "Long"
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Try setting manual channel 1, 6 or 11 on 2.4Ghz on the RBR.
    Has a factory reset and setup from scratch of the RBR and RBS been performed since last update?
