arune00
Jan 19, 2023Follower
2022 Subaru won’t connect to my orbi WiFi mesh system.
I recently purchased a 22 Subaru WRX and it won’t connect to my Orbi. My 21 WRX connected fine. My 22 will not. Sometimes it says it can’t connect. Other times it says the password is incorrect. I’ve changed the password, disabled 5hz, rebooted. Reset to factory defaults, reset car head unit, even set up a guest network. No luck. I used to have another WiFi mesh system that it connected to no problem. Also noticed my ps5 will take 10 minutes or so to connect. All other devices connect just fine. System is an rbs750. Any ideas?
1 Reply
You're using the RBK750 kit?
What firmware is on the router?
And on the satellites?
What modem/gateway is the router connected to ?
Are you using ipv6?
Are you using any special characters/spaces in the ssid/password? If so, remove them
