SarahJs
May 22, 2024Aspirant
5/22 Update and one router will not reconnect
The good news is for the first time since I have had my RBK653 tri mesh system, I was actually able to update the router via the Orbi app. I received a message to update, so I did. All appeared to ...
- May 24, 2024
Not sure if or when that will happen. Best recommendation is to keep this same FW loaded for now. Avoid updating the RBR. If nothing updates for the 350 series RBS, you could find some new/used RBR750s and load them up to v7 FW then the RBR lastly. Otherwise, run it as is for now.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 22, 2024Guru - Experienced User
Please downgrade the RBR back to v4 version of FW:
v7 FW from RBK 7 series systems is NOT compatible with RBS350 series.
SarahJs
May 23, 2024Aspirant
I just uploaded the zip file from the Orbi page for v4.6.14.3. I tried to upload manually to my RBR750 router. Tried twice and both times it failed. I am under the advanced admin router, firmware update. It tells me to check my file as a solution
- FURRYe38May 23, 2024Guru - Experienced User
Be sure you are unpacking the RBR70#######.CHK file from the .zip file and sending this file to the RBRs web page.
What browser are you using? I recommend MS Edge or Firefox.
Can follow this PDF to load the RBR.
Skip over any RBS steps.
- SarahJsMay 24, 2024AspirantThank you!! It worked on my phone this morning. Router and both satellites connected once the manual update finished and rebooted the router. On my Orbi app, everything is back to v4.6.3.16 but there is a red msg from Orbi to update. How will I know when they figure out the satellites and allow them to be compatible with the new suggested router update?
- FURRYe38May 24, 2024Guru - Experienced User
Enjoy. 📡
