PJDarwin's avatar
PJDarwin
5G Solution in Australia
I currently have an RBK852 connected to Gigabit Fibre but I am moving to a larger house that does not have fibre available so looking for a 5G solution and have come up with the following solutions.
1) Keep my existing router (RBR850) and satellite (RBS850), add two extra satellites (RBS850B2) and a Nighthawk M6 Pro for 5G connectivity
2) Buy an NBK753, ordered from US as not currently available in Australia, utilise my existing RBS850 as the third satellite (which I believe should work) and give away the RBR850 (or I have read somewhere that you can change the firmware so the router acts as a satellite)
3) Ditch Orbi and go for a different system.
Any advice appreciated
  • plemans's avatar
    If it was me? I'm a fan of keeping everything integrated. I'd be going with option 2 if it'd work in AU since its only US based currently.
    It even has a wan port if you do ever get fibre/dsl/cable for your home.
    How big is the home your moving to? the 8 series can cover quite some area. Not sure how many actual satellites you need.
