Karen_mckenzie's avatar
Jul 31, 2020
Acer chromebook won't connect to wifi
I just purchased and set up the Orbi 6 from Costco.  Everything connected perfectly (screaming fast speed) except for my Acer Chromebook.  It sees the Orbi, but when I try to connect I get this error: "Failed to connect to network ORBIXX: Unrecognized error: no-associated."
Help!
  • CrimpOn's avatar
    CrimpOn
    Would love to help, but unfortunately you posted in the community forum for the "Original Orbi" from 2016, not the new Orbi AX product.
    There is a forum for that product: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    You will probably get a more informed response if you post in that forum where participants have the same system.
    A Google search turned up a number of posts about similar problems with Chromebooks and WiFi.  Maybe it would be worth checking that the Chrombook does connect to other WiFi networks successfully?  Perhaps there is some way to get a more detailed explanation of the problem?
  • FURRYe38's avatar
    Any progress on this?
    What happens if you disable AX Mode?
    Try setting CTS to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
    Help!
    Help!
    Change the CTS setting to 2347.  I had the same issue with the kids' Lenovo Chromebooks that were furnished by their school and it wouldn't connect until I changed the CTS setting to 2347, and the fix below worked.
    https://community.netgear.com/t5/Orbi-AX/Chromebooks-refuse-to-join-Orbi-WiFi-6-network-AX6000/m-p/1889133/highlight/true#M2737
  • FURRYe38's avatar
    Help!
