nsapcor's avatar
nsapcor
Tutor
Jul 28, 2021
add third satellite to RBR850
My current setup is RBR850 router with two RBS850 satellites, one wireless and the other ethernet. I want to add a third satellite via ethernet but the port currently is wired to a desktop. Is a solution a splitter (or switch or some other device) from the port to the desktop and new satellte.   What make and model would best be suited? The input wifi signal is 490 mbps
  • "I want to add a third satellite via ethernet but the port currently is wired to a desktop." What port are you referring too?
