Teddy123TutorSep 02, 2020Adding three satellites to AX6000 RBK 853Hello,Is it possible to add three addtional satellites to an AX6000 system that comes with two satellites?Many thanksTeddy123
3 RepliesReplies sorted by OldestKKSigsGuideSep 02, 2020I believe soTeddy123Tutor to KKSigsSep 02, 2020Many thanks and for such a rapid resonse!FURRYe38Guru - Experienced User to Teddy123Sep 02, 2020From what others have posted, NG seems to only officially support 4 RBS total wirelessly. I presume if you wired the RBS, they should work in that configuration. Let us now if you get them all connected. Teddy123
