klp110's avatar
klp110
Follower
Sep 06, 2020
Adding Z wave with WPS
I am having difficulty add Jalsco (Honeywell-zw3104) Z wave dimmer to my network using the WPS to my Orbi RBK853 router/network. I have replaced a previous network and everything worked just fine.  Any suggestions?
  • schumaku's avatar
    schumaku
    Can't find much on this product, but what I see it's a Z-wave dimmer sold under different brands. Either way, I doubt it does connect direct to a Wi-Fi network. Is it possible your old router came with some Z-wave interface or there is a Z-wave gateway/controller in the game?
    Do you have a Hub setup for the Zwave product?
  • CrimpOn's avatar
    CrimpOn
    The previous network appears to be the key question.  There are some residential WiFi routers that include Z-Wave and Zigbee. The Orbi does not.
    So, exactly which router was installed when "everything worked"?
