Empire014
Feb 17, 2026Aspirant
Additional RBS 750 satellite won't connect to RBR 750 Router
I have an existing RBR 750 router with 2 satellites connected to it for about 4 years now, the system is up to date with its firmware and updates. I bought a standalone satellite to connect to the ro...
- Feb 17, 2026
Gents,
Thanks so much for the assist. Talk about Netgear creating a nightmare to add additional equipment after the fact if the firmware doesn't match.
The original means of trying to do it with the static IP address all initially failed. I ended up doing the following.
- Plugging it directly back into the original router.
Find it on the attached devices, take its IP address, and input
it into the browser.- It took me to the satellite's standalone Orbi webpage, where I was able to manually update the firmware
- Once all of that was done and a power cycle, it showed up as a satellite and then was able to add it to the router network finally.
Appreciate all the help with this!
Empire014
Gents,
- FURRYe38Feb 18, 2026Guru - Experienced User
Glad you got it working.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
