gobuffs21's avatar
gobuffs21
Admin Login Orbi RBR750
Hello, trying to log into the admin settings and I keep getting prompted to reset my password.  I go through the steps of entering serial number, answering security questions, entering new password, and then the process repeats itself with the reset my password page.  Thanks for any help you can provide.
  • FURRYe38's avatar
    Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
  • Thank you!  That worked!  I would add to also write down the name of your network and after reset use the same name and password. Otherwise you need log back into all your devices.  I couldn’t remember the exact name of my network so that caused extra work.  Anyway, thanks again
