rusty99
Sep 23, 2025Tutor
Advice before purchase
I'm living in a timber farmhouse in a remote area that has no cell reception. I have a dual 4G dual antenna on the roof that points to a cell tower 5 miles away over the hills and is connected to a 4G modem (GL-X750 Spitz v2 CAT 60). The modem is robust and the speed of 15Mbs max is adequate for cell phone calls, internet browsing and streaming, but obviously not blazing.
What I want to do is push the signal down to the garage, 16m (52ft) from the modem and out into the house paddock to 20m minimum (66ft). There are 2 timber walls between modem and garage and glass on the sides pointing to the paddock. I was looking at the RBK 852 and the RBK 625 2-packs for their range, not their speed, though I don't want to spend more than I need to.
I gather I'd plug the Orbi base 'modem' into the ethernet port of the 4G modem then the single satellite would work off the signal from the Orbi modem, and they both push out a wifi signal I assume the 4G modem would work with an Orbi?
My question is, what is the realist range of the signal from these devices, mine would be straight line through glass, so I can get cell over wi-fi reception outside of the house to a reasonable distance. I'm assuming the ones published are theoretical so I'm looking for real world ranges.
Orbi mesh systems are intended to provide high performance wifi coverage inside a house (or building). You are wanting something a bit different, so it's hard to say how well it would work. Among other things, it depends on how far the paddock is from the garage.
There are some other possibilities you could consider. If the garage and paddock are both getting AC power from the house circuit breakers, then you might consider trying powerline networking. There are powerline systems that have built-in WiFi. Netgear used to make some (not sure if they still do), and of course there are other vendors. That would be your least expensive option, so worth a try.
Another option is to get an outdoor wifi system, and connect it with ethernet to your existing modem (or router if that is separate). Cost would probably be similar to the Orbi system, and those products are a better fit for what you want to do.
- rusty99Tutor
Thanks for that info, and to clarify, the house paddock is outside the front door as it used to be a working farm. The Orbi blurb states that their devices can cover courtyards as well as houses, so I was hoping to get coverage throughout the house as well as an unknown distance outside.
20-30 feet coverage outside of the home. Beyond that, would be a stretch.
- JWS9518Luminary
You might also want to look into Ubiquiti outdoor antennas as an option as well. We use those in our community to connect security cameras to a NVR and network.
