yatesaw19
Feb 05, 2026Aspirant
AirPrint issues
RBR850 mesh Ios devices IOS 26.2 Canon TS8150 printer for a few years I have been printing from various IOS devices around my home. over the last few weeks all of the iOS devices have been st...
- Feb 06, 2026
yatesaw19 wrote:
Orbi Firmware V7.2.8.2. On router and all satellites. firmware update check from within router admin shows no update available.
You can manually update the firmware (downloading from these links):
- https://www.netgear.com/support/product/rbr850
- https://www.netgear.com/support/product/rbs850
yatesaw19
Feb 06, 2026Aspirant
Hi Stephen,
Thanks for your suggestion.
Manual firmware update to all satellites and router appears to have solved my issue (Why auto update didn’t do this I don’t know!)
Thanks for your help
Feb 06, 2026Guru - Experienced User
Just FYI, some FW updates may not be pushed down by NG via the auto update system. If I remember right, minor updates are not put up for AU. Major updates or major FW update revisions are.
Also NG may not push new FW out to ALL at the same time. May push in small batches. Historically, NG would push to all and cause problems. NG seems to have learned from that.
Enjoy. 📡
