Flupke's avatar
Flupke
Apprentice
Jan 08, 2022
an RBS850 satellite has specific password
I am facing a strange issue,
One of my two RBS850 satellites, properly connected to the RBR850, has a misaligned consolde password: it is still based on default "admin/password" (not admin/admin) while I have of course a specific password defined at the level of the router.
For the rest the satellite seems to be up and running and fully operational (except for occasional temporary disconnection that I hope the new but still unofficial firmware will resolve - awaiting the official version before trying)
The other satellite does not have such issue btw.
  • plemans's avatar
    What firmware is on the satellites and the router?
    Have you tried a simple factory reset and  reinstall?
    Maybe the re-sync will update the password info.
    • Flupke's avatar
      Flupke
      Apprentice
      THey are properly aligned on the last official firmware: V4.6.3.16_2.0.51
      I am not willing to do a factory reset of the router due to a rather complex configuration that would be tedious and disruptive to redo.
      I may however try to remove/resync the satellite itself, as some have report this as resolving such disync issue. Alternatively, I could keep it as such as everything seems to work for the rest ...hoping the next firmware update (apparentely on its way) would resolve it.
      • plemans's avatar
        sorry, didn't mean a factory reset of router, just the satellite.
        I'd try that first.
  • FURRYe38's avatar
    I recommend that if you can get access the RBS web pages, update FW on the RBS first, then RBR lastly.
    https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-v4-6-7-5-Released/m-p/2182138/highlight/true#M25415
    Follow the post instructions after FW has been loaded on the units.
