jimmyngtm's avatar
Dec 23, 2021
Anyone has difficulties connecting their shelly relay to Orbi RBK852 wifi network?
I recently got my hands on Shelly 2.5 relay, and it just won't connect to my Orbi RBK852 router.
Have tried disabling AX, enabling guess wifi, lowering 5ghz channel to 25%, setting static IP for the relay, but to no avail.
Has anyone encounter similar issue? I am starting to lose hope as I suspect it is a compatibility issue, which means I either need to get another set of router or give up on Shelly.
Appreciate any input from anyone, thanks!
  • plemans's avatar
    1 thing to try is to make sure the device you're using to setup the IoT device is on the 2.4ghz network.
    You also might check on the Shelly website/forum as they tend to be a little less user friendly and for more advanced users.
    • jimmyngtm's avatar
      jimmyngtm
      Tutor
      The orbi rbk853 is with mesh wifi network and there is no standalone 2.4ghz and 5ghz channel. The router is supposed to figure out what channel the device is using. Hence I tried to weaken the 5ghz channel but that still does not work :(
      • plemans's avatar
        the problem is with coding. A properly coded IoT devices doesn't care if your phone is on 2.4ghz or 5ghz. The ones that are coded poorly or by a lazy coder do care. So if you're phone isn't on the 2.4ghz it won't setup .
        You have options. You tried turning down the broadcast power. You can also disable the ssid broadcast (doesn't stop the radio). And then move as far from the router as you can. Then disconnect your phone from the wifi and reconnect. see if it connect to the 2.4ghz. if it does, try setup. If it doesn't, then we'd need another option.
        I've hotspotted my phone before with the same ssid as my router (shut off the router). I've used that to get the IoT device setup on the ssid. then I simply shut off the hotspot and turned the router back on. I haven't had to do that in years and it was many on cheap/poorly coded devices.
