Ransak
Nov 13, 2021Aspirant
App confusion
Is anyone here? I have a CBR750 modem/router and have the upgraded VPN via the Bitdefender mobile app. After online chat with NG, I uninstalled that VPN and went through the VPN installation via th...
- Dec 01, 2021
FURRYe38 and michaelkenward You are the only people to respond to me. Thanks. As I mentioned earlier, I did post to one of your recommended forums. Here's the result: https://community.netgear.com/t5/NETGEAR-Armor/App-confusion/m-p/2162736/highlight/false#M5627
michaelkenward
Nov 14, 2021Guru - Experienced User
As you are asking about the CBR750 and Armor you might get better luck asking in the appopriate sections rather than a zone given over to Nighthawk WiFi Routers.
NETGEAR Armor - NETGEAR Communities
Orbi with Built-in Cable Modem - NETGEAR Communities
Your issues are unlike the generic stuff that can be answered anywhere.
- RansakNov 14, 2021Aspirant
Thanks! I'll do that.
BTW, I did try to enter cbr750 in the "Model" window (to help the community give the best answers) but that's not allowed and the window defaults to Knighthawk.
michaelkenward thanks again, and I don't have any problem with this being deleted from this thread. I can't delete it myself, right?
- FURRYe38Nov 14, 2021Guru - Experienced User
IF not deleted, we'll get it moved for you.
Thanks, I copied it to the first link that michaelkenward listed.
- michaelkenwardNov 14, 2021Guru - Experienced User
Don't worry about it. If Netgear makes it hard for people to work out where to post queries why should we worry when things go astray?
