Ransak
Nov 13, 2021Aspirant
App confusion
Is anyone here? I have a CBR750 modem/router and have the upgraded VPN via the Bitdefender mobile app. After online chat with NG, I uninstalled that VPN and went through the VPN installation via th...
- Dec 01, 2021
FURRYe38 and michaelkenward You are the only people to respond to me. Thanks. As I mentioned earlier, I did post to one of your recommended forums. Here's the result: https://community.netgear.com/t5/NETGEAR-Armor/App-confusion/m-p/2162736/highlight/false#M5627
michaelkenward
Nov 14, 2021Guru - Experienced User
As you are asking about the CBR750 and Armor you might get better luck asking in the appopriate sections rather than a zone given over to Nighthawk WiFi Routers.
NETGEAR Armor - NETGEAR Communities
Orbi with Built-in Cable Modem - NETGEAR Communities
Your issues are unlike the generic stuff that can be answered anywhere.
Ransak
Nov 14, 2021Aspirant
Thanks! I'll do that.
BTW, I did try to enter cbr750 in the "Model" window (to help the community give the best answers) but that's not allowed and the window defaults to Knighthawk.
