Ransak
Nov 13, 2021Aspirant
App confusion
Is anyone here? I have a CBR750 modem/router and have the upgraded VPN via the Bitdefender mobile app. After online chat with NG, I uninstalled that VPN and went through the VPN installation via th...
- Dec 01, 2021
FURRYe38 and michaelkenward You are the only people to respond to me. Thanks. As I mentioned earlier, I did post to one of your recommended forums. Here's the result: https://community.netgear.com/t5/NETGEAR-Armor/App-confusion/m-p/2162736/highlight/false#M5627
michaelkenward
Nov 14, 2021Guru - Experienced User
As you are asking about the CBR750 and Armor you might get better luck asking in the appopriate sections rather than a zone given over to Nighthawk WiFi Routers.
NETGEAR Armor - NETGEAR Communities
Orbi with Built-in Cable Modem - NETGEAR Communities
Your issues are unlike the generic stuff that can be answered anywhere.
Ransak
Nov 14, 2021Aspirant
michaelkenward thanks again, and I don't have any problem with this being deleted from this thread. I can't delete it myself, right?
- FURRYe38Nov 14, 2021Guru - Experienced User
IF not deleted, we'll get it moved for you.
- RansakNov 14, 2021Aspirant
Thanks, I copied it to the first link that michaelkenward listed.
- michaelkenwardNov 14, 2021Guru - Experienced User
Don't worry about it. If Netgear makes it hard for people to work out where to post queries why should we worry when things go astray?
