steinOA
Nov 21, 2022Follower
Are ORBI RBK352 AX1800 compatible with RBR20
Have a Orbi RBR20 with two sattelites and want to extend with an extra satellite.
Didi find an BlackWeek offer on RBK352 router and satellite.
Will these be compatible?
No. They won't be.
For the RBR20 system you'd need either:
RBS20, RBW30, RBS40, RBS40V, RBS50, RBS50Y
You can also use the rbs10 but its a dual band and not triband
No. They won't be.
There's another chart to if you plan on upgrading at some point.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
