MK2022's avatar
MK2022
AX WIFI on ORBI RBK 752 - 2 pack mesh
In order to enable AX WIFI connection on the ORBI RBK 752, do I need to set up my WIFI network using WPA3? In such case, are older devices capable of connecting to this network on AC or 2.4 GHz frequencies?
Thank you.
1 Reply
  • plemans's avatar
    No.
    You can use wpa2. Some older devices don't function/struggle with wpa3.
    AX will still work fine.
