td318's avatar
td318
Follower
Apr 19, 2025
AX3000 Mesh WiFi 6
192.168.1.1 will not connect from a laptop. Turned off VPN Turned off Firewall Turned off Anti-Virus   still won't connect tried different Browsers Still nothing.
Hmmm… can't reach this page
192.168.0.1 took too long to respond
Try:
ERR_CONNECTION_TIMED_OUT
192.168.1.1 took too long to respond
  • FURRYe38's avatar
    What browser are you using? Be sure to clear out all browser caches.
    Try a different browser.
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed?
    Which Orbi model do you have? 350, 750 series?
  • plemans's avatar
    What device do you have?
    Did you try 10.0.0.1
