DJ1964's avatar
DJ1964
Guide
Apr 16, 2020
AX4200; can I connect my current Dlink router
Hi - i have comcast cable internet and currently a dlink wifi router.  can i connect the cable modem to the orbi ax4200 router, and then connect the dlink router to either the orbi router or its satellite, and run wifi on both routers?  Or will they interfere, etc?  Or will performance be affected?  If possible it would be nice to keep the house up and running on the old SSID while i'm kicking the tires on the orbi.
Thanks in advance.  I'm going to install tonight i think.
Doug
  • Glad that worked for and your getting great speeds. Sounds like time to enjoy now. :smileywink:
  • FURRYe38's avatar
    I would try the Orbi AX system out using the old SSID name and PW first and see howe the system works for you.
    Having two wifi sources can effect and cause problems in the home... Thought you could connect the DIR router in wired AP mode and have a separate SSID on that router. You will need to keep the wifi channels between the two far appart. I.E. one system using channel 1 and the other usng channel 11 on 2.4Ghz.
    What is the model of the DIR router?
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    • DJ1964's avatar
      DJ1964
      Guide
      Thanks for replying.  Its a dlink dir-880L and my home is about 1750 up and 1750 down.  the router will be near the southwest corner and I think the satellite I'll be able to  put about 30 feet away in the living room towards the northeast corner.
      Maybe I'll scrub the idea and just go full bore and see how she goes.  Not like I don't have some time on my hands to figure things out and get everything connected to the orbi....and if I don't like it, I can just spend some time reverting back.
      Thanks for the link.  if you have any other suggestions or things to do and things to avoid, please let me know.
      • FURRYe38's avatar
        Yes try the system out first by itself.
        You can use the DIR as a wireless media bridge if needed.
