defiler2k's avatar
defiler2k
AX4200 Magenta light and Internet drop daily
I have been facing the issue that my router drops connection to the internet daily. The router goes to the solid magenta light, none of the wired devices can even communicate with it and I can only connect to it using the orbi app. After a reboot (either by pulling the power cable or via the app) everything seems to work fine for a day however, next morning I get up to the same issue.
Ive tried rebooting the cable modem, new data cables yet I still have the same issue every morning.
Hardware is the RBR750 firmware 4.6.5.14, with 2 satelites (RBS750) hardwired.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    • defiler2k's avatar
      defiler2k
      The cablemodem is an Arris Surfboard 8200, has been working just fine until Friday. Yes both devices have been power cycled (full disconnect for over a minute) and the router has been factory reset.
      From the article, there is no description for what solid magenta represents.
      • FURRYe38's avatar
        Ya, that KB article needs to be updated.
        Theres BLUE when the RBR connects then turns OFF or ON with Magenta solid if the RBR looses the connection to the modem or the modem fails to give an IP address to the RBR. I'll have NG review this article and get it updated.
        Blanca_O
        What is the CAT# of the cable in between the modem and RBR?
        Try a different cable to check this.
