CHuntMD
Aug 04, 2026Aspirant
AX4200 with 3 satellites hard wired
I have 3 RBS750 plugged directly into the back of the RBR750. My wireless devices all drop wifi at random times. Google AI is telling me that a backhaul status of Good is not correct for a wired con...
Aug 04, 2026Guru - Experienced User
What firmware version is on the system?
What CAT# LAN cable are you using between the RBR and RBS? CAT6 is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
What model# is the LAN switch?
Yes you can connect the RBS to the back of the LAN switch and then connect the LAN switch to the back of the RBR.
BH status of GOOD IS correct for both wireless and wired RBS.
