Captainmichael7
Nov 20, 2021Aspirant
Ax6000 download speeds max at 94 mbps via ethernet and wifi
I am only receiving 94 mbps via wifi and ethernet on all devices.. new orbi rbk 853 setup.. I have changed multiple settings and I have now downgraded firmware.. I am stuck at 90 mbps... If I connect ethernet directly from modem to pc I receive 460 mbps or if I connect to my old nighthawk router I receive 460 mbps hardwired to pc and wifi to all devices...
Downgraded firmware to 4.6.3.9
Spectrum 400 mb internet
e31u2v1 spectrum modem
Makes no sense at all??? Please help
- Yes, that is correct.. still only shows 100 mbps
Be sure your using good quality LAN cable between the ISP Modem and RBR.
Check the RBRs status connection button on the RBRs web page under Advanced Tab/Internet section. The WAN port connection should read 1000Mpbs...Be sure your getting same 1000Mpbs connection rate between your wired PC and the RBR.
Has a full power OFF of the ISP modem and RBR for 1 minute or more then back ON been performed?
- Captainmichael7AspirantThe wan port only shows 100m despite using the same ethernet cable I am receiving full bandwidth when switching to older nighthawk router and even tried two brand new cat 7 ethernet cables.. multiple reboots have been done
Do you have your prior router on hand by chance? If so, you don't have to connect the old router to the modem, just power ON the old router and connect the WAN port of the RBR to the LAN port of the older router. Check the connection status again on the RBR. If it doesnt' change to 1000Mpbs, I presume the RBR is faulty and needs replaced.
