J-dawg83's avatar
Mar 20, 2022
AX6000 Orbi RBK853 wifi disconnects
Hi there 🙂
I'm at the point where im almost pulling out my hair haha
My setup is as follows:
Network Terminating Unit - supplied by ISP (CABLE)
My personal router - D-link DSR 1000AC
Orbi connects to the above router LAN port 1
Orbi setup went smooth but then realised WIFI was dropping in and out. I was watching my phone as I was sitting next to one of the satellite speakers and could see the signal drop by half, then disappear and then my phone would switch to 4g. Sometimes its stable for an hour or two then i see it dropping in and out again.
I have been in touch with support who suggested changing the channels and MTU etc but nothing has fixed this. The firmware is up to date.
I also ruled out my personal router as being the issue by removing it and setting ORBI up as the main router. That also worked fine but could then found WIFI signal was still dropping out on the satellites. The WIFI from the main ORBI router seemed stable as far as I could tell.
Any other tests I can do here. Is there a way to tell which router/satellites are dropping out?
  • Thanks everyone for trying to help.
    I have tried a lot of things now, none seemed to have work... after 4 solid days of trying to work this out, I have given up and requested refund. I have now switched to Unifi routers which work a dream around my property. I'm not sure why Orbi was so difficult, would have thought an off the shelf product would be more plug and play given the price tag. Software was also rather average, disappointing 😞
  • One thing i did forget to mention, I am running ethernet backhawl
    Oh and its a RBR850 not RBR853
    • plemans's avatar
      What firmware is on the router and on the satellites?
      • J-dawg83's avatar
        J-dawg83
        Guide
        Hey mate 🙂
        All 3 including router are sitting on V4.6.3.16
